Author Topic: A Look Inside #4 - Heath Built Voltage Reference Source (1960's) - EUW-16A  (Read 14838 times)
A link to the video here: http://youtu.be/e_SGHSnV1TU
I take a look at the Heath Built Voltage Reference Source model EUW-16A which dates back to about 1967. We have a look at its operation as a millivolt to 100 volt voltage reference source and then open it up and take a look inside.
Here is a link to a wiki that talks about VR (voltage regulation) tubes:
http://en.wikipedia.org/wiki/Voltage-regulator_tube
« Last Edit: October 04, 2013, 06:26:32 PM by MJLorton »
Looks like a nice bit of kit Martin :)
It would go nicely with something like an old AvoMeter.
Nice unit, just needs a good switch clean, a new set of capacitors ( 50 year old electros are 30 years past the best before date) and a 220V transformer and I will happily use it. Nice KV divider bridge there. Only issue is that output voltage is only really accurate at close to zero current.
I would take the old caps out carefully, strip them apart and then open the case, clean out the old junk inside and place new modern units inside, as the case looks so nice. Values would change though, to 100uF 450V for the first one and 100uF 200V with a series 100R 1W resistor for the second one. The 100n  cap to ground would be changed as well to a 100n 630V unit, along with the 1uF output capacitor being changed to a good 1uF 400V foil type. Circuit diagram shows a second cap to ground, seems to not be present in the unit.
If you wanted nmore accuracy the only way is to replace the zener diode with a series connected string of 6V8 diodes, about 16 in series adjusted to a zero TC current would make a low noise relatively stable replacement for the avalanche diode, giving 108V as a stable source.
As to a switch cleaner, first will be to go to Amazon and buy 2 bottles of Caig Deoxit and the Caig cleaner, and use them to clean the switches using a ear bud to wipe each contact. Then place a drop of light mineral oil ( not from a spray can) on each of the bushes and each of the pot bushes so that it can soak in. You might want to have a spray bottle of the Deoxit to spray into the pots as well to clean them, though you will have to move them from end to end after application and then run through the full calibration procedure afterwards to get the currents right. That will make each switch operate like new again, though you will have to look on the side of those loose knobs to find the small hex ( 1/64 IIRC) grub screw that locks the shaft and remove it, clean the shaft and then tighten it again. If the screws have cracked then a small bit of 2 part steel epoxy works well to lock it again rather permanently.
« Last Edit: October 05, 2013, 01:53:00 AM by SeanB »
Paul Collins M0BSW
I love this  heath & heath kit equipment, things seemed to built bomb proof and properly back then, unlike my 4 year old plasma TV knackered after 4 Years, when it's cheaper to buy a new one than the parts for this one, ridiculous situation .
Quietly Learning
Funny enough I found a replacement for the hex driver is a Torx driver. i was at the Ham meeting this morning and needed a hex key to do the grubscrew in a tranciever there. went to the flea market ( it is held at a club with a flea mart next door so was worth it anyway) and found a small set of Torx and security bit set for $2.50. The smallest one fitted perfectly, and I now have another set of security bits, though these are quite long so are more useful.
Just wondering Martin, are you planning to make use of this, or is it more of a curiosity?
I would say more curiosity for the Heath...but once I have some time on my hands I'm keen to follow Sean's advice to get it back to full working order again.
I have just received the original manual for the Fluke 332D so that will also be up for a "Look  Inside" at some point....the 332D beast I do intend to use.
Thanks for the advice Sean.
G7PSK
Those Valves are not valves, They are gas discharge tubes neon to be precise. Marconi used to make them with several tapping's so that you had different voltages from the one tube. They rely on the voltage across the tube is pretty stable despite variations in current. I have a bit about them in a 1948 book "Electronic Engineering" edited by E. Molloy I am attaching a PDF scan of the relevant page I have some more information somewhere that I will dig out, just got to find the book.
