Author Topic: Tape deck Sony TC FX 510R  (Read 17296 times)
RobertoLG
« on: January 29, 2016, 09:42:33 PM »
another oldie fully working, and the sound quality is really good
Specifications
Type: auto reverse, 2-head, single compact cassette deck
Track System: 4-track, 2-channel stereo
Tape Speed: 4.8 cm/s
Heads: 1 x record/playback, 1 x erase
Tape Type: type I, Cr02, Metal
Noise Reduction: B, C
Frequency Response: 20Hz to 18kHz  (Metal tape)
Signal to Noise Ratio: 71dB  (dolby C)
Wow and Flutter: 0.045%
Total Harmonic Distortion: 1.0%
Input: 77.5mV (line), 0.25mV (mic)
Output: 0.44V (line)
Dimensions: 430 x 105 x 275mm
Weight: 4.7kg
« Last Edit: March 20, 2019, 11:08:30 PM by RobertoLG »
Re: Tape deck Sony TC FX 510R
« Reply #1 on: January 29, 2016, 11:56:29 PM »
Every single part in that was made in Japan, from the steelwork, using steel made in Japan from imported iron ore, the motors and the components, either made by Sony themselves, or bought in from other Japanese manufacturers like Matsushita and then assembled by hand mostly ( most sub assemblies were supplied by subcontractors who might have used automation in parts) to make this.
A far cry from the present Sony, where most is made in automated factories outside Japan.
