• Arduino Tutorial #5 – Digital Voltmeter, Arduino Analog to Digital Converter
    Posted in: Arduino
    We look at a digital voltmeter project and how it used the Arduino analog input.
  • In this tutorial we look at a digital voltmeter project and how it used the Arduino analog input. This involves understanding ADC or analog to digital converters and how they work. We also troubleshoot why the output reading on the LCD display is noisy.
    We also gave a quick peek at the Arduino DUE: http://arduino.cc/en/Main/arduinoBoar…
    Thanks to Clarence of “Clarence’s Wicked Mind” for the original code that I used and updated for this project: http://www.clarenceho.net:8123/blog/a…
    The sketch / project code for the digital voltmeter:: http://mjlorton.com/forum/index.php?t…
    Also read Measuring Stuff – The Arduino DAQ Chronicles: https://sites.google.com/site/measuri…
    The Arduino Due is a microcontroller board based on the Atmel SAM3X8E ARM Cortex-M3 CPU (datasheet). It is the first Arduino board based on a 32-bit ARM core microcontroller. It has 54 digital input/output pins (of which 12 can be used as PWM outputs), 12 analog inputs, 4 UARTs (hardware serial ports), a 84 MHz clock, an USB OTG capable connection, 2 DAC (digital to analog), 2 TWI, a power jack, an SPI header, a JTAG header, a reset button and an erase button.
    Buy the Arduino DUE here: http://astore.amazon.com/m0711-20/det…
