Oscilloscope Reviews
Posted in: Consumer ReviewsReviews, tests and comparisons of various oscilloscopes
1. The Hantek DSO-1200 oscilloscope and the Fluke 43bIn this video I do a basic demonstration of the Hantek DSO-1200 oscilloscope as well as the Fluke 43b oscilloscope function. I demonstate some of the functionality and trouble shooting around my solar powered Kindle DX project. I talk a about supercapacitors and show a nornal capacitor working in conjuction with a voltage regulator.
Details:
http://www.kmeasure.co.za/electronic-…Digital Oscilloscope Specifications:
. Dual Channel oscilloscope
. 500 MSPS sampling rate
. 200 MHz bandwidth scope
. 8 bit resolution
. Isolated groundDigital Multimeter Specifications:
. Multimeter Testing modes: Voltage, Current, Resistance, Capacitance, Diode and Continuity
. Max input voltage: 800 VDC & 600 VAC
. Max input current: 10 A (AC&DC)
. Max input impedance: 10 M?
. Isolated groundGeneral Technical Specifications of Scopemeter:
. USB2.0 PC-Interface (Optional RS232 & LAN)
. Battery or AC powered (6 hours battery life)
. Large 320×240 backlit display (14.5cm / 5.7inch)Scopemeter Software Features:
. Very intuitive UI (user interface).
. 23 oscilloscope measurements including:Min/Max, Overshoot/Undershoot, Mean, RMS, +/- duty cycle and rise/fall time.
. Horisontal and Vertical Cursors.
. FFT analysis (Spectrum Analyser).
. X-Y (circular) plotting of data.
. Mathematical functions on oscilloscope waveforms, e.g. Ch3 = Ch1+Ch2.
. 1000 Waveforms can be stored and retrieved for comparison.
. Pass / Fail Testing.The Scopemeter Package Includes:
DSO1200 Oscilloscope & Multimeter, two 200MHz Oscilloscope Test Probes, two Multimeter Probes, USB cable to connect oscilloscope to PC, AC Power Supply, Printed User Manual, PC-Software CD, travel bag. -
2. The Xytron DSO1042CML (Aktakom / Atten ADS1042CML)I do a brief review of the Xytron DSO1042CML (Aktakom / Atten ADS1042CML) in reference to the Hantek DSO1200 and Rigol DS1052E. (Siglent SDS1102CML)
Equipment used:
CIGS thin film solar panel
Amazon Kindle DX
Fluke 115 digital multimeter
Fluke 287 digital multimeter
Brymen 867 digital multimeter
Brymen 251 digital multimeter
Thurlby Thandar Instruments Precision Linear 30V 3A variable power supply
Digital Storage Oscilloscope DSO1042CML
Supercapacitors
FRS1-S 12 Volt relay
Solderless breadboard -
3. The LeCroy WaveJet 324A OscilloscopeI use my Amazon Kindle super capacitor solar charging circuit to demonstrate some of its functionality…. it’s a nice piece of kit.
Thanks to Comtest (www.comtest.co.za) for the loan of this Oscilloscope.
Specs:
200 MHz, 1 GS/s, 4 Ch, 500 kpts/Ch with 7.5″ Color Display. 2 GS/s InterleavedVertical System
Bandwidth 200 MHz
Rise time 1.75 ns
Input Channels 4
Bandwidth Limiters 20 MHz
Input Impedance 1 MΩ ± 1.5% || 20 pF
Input Coupling AC, DC, GND
Maximum Input Voltage ± 400 Vpk
Channel-Channel Isolation ≥ 34 dB from DC – 100 MHz
≥ 30 dB at 200 MHz
Vertical Resolution 8 bits
Sensitivity 2 mV/div – 10 V/div
DC Gain Accuracy ±(1.5% + 0.5% of Full Scale)
Offset Range ±1 V: 2 mV/div – 50 mV/div
±10 V: 50.2 mV/div – 500 mV/div
±100 V: 502 mV/div – 10 V/divHorizontal System
Time/Division Range 2 ns/div – 50 s/div
Clock Accuracy 10 ppm
Trigger and Interpolator Jitter 500 ps (pk-pk) -
4. The UNI-T UT81B ScopemeterBuy the UT81B here: http://astore.amazon.com/m0711-20/det…
Other oscilloscopes: http://astore.amazon.com/m0711-20?_en…
The UT81B is a multimeter / oscilloscope hybrid (scopemeter) that could be very useful to an electronics hobbyist / enthusiast.Details:
Basic Functions Range Best Accuracy
DC Voltage 400mV/4V/40V/400V/1000V (0.8%+8)
AC Voltage 4V/40V/400V/750V (1%+15)
DC Current 400mA /4000mA/40mA/400mA/4A/10A (1%+8)
AC Current 400mA/4000mA/40mA/400mA/4A/10A (1.5%+8)
Resistance 400W/ 4kW/40kW/400kW/4MW/ 40MW (1%+5)
Capacitance 40nF /400nF/4mF/40mF/100mF (3%+8)
Frequency 10Hz~10MHz (0.1%+3)
Vertical Accuracy (5%+1)
Input Sensitivity 20mV/div-500V/div (1-2-5)
Horizontal Accuracy (0.01%+1)
Timebase Range 100ns/div-5s/div (1-2-5)
Bandwidth 8MHz
Display Resolution 160X160
Real-Time Sample Rate 40MSa/s
Duty Cycle 0.1%~99.9%
Special Functions
Diode -
5. The Keysight (Agilent) MSO-X 3000T oscilloscope Part 1This is a review of the new Keysight (Agilent) MSO-X 3000T oscilloscope. I do a side by side comparison with the Tektronix MDO3000 oscilloscope
http://www.keysight.com/main/campaign…
http://www.tek.com/oscilloscope/mdo30…
Other reviews:
Dave Jones / EEVblog: https://www.youtube.com/watch?v=FtcZ9…
Afrotechmods: https://www.youtube.com/watch?v=9GPvQ…
6. The new Keysight (Agilent) MSO-X 3000T oscilloscope Part 2I do a side by side comparison with the Tektronix MDO3000 oscilloscope
Other reviews:
Note that the playlist content description and the video title may differ,
Please support MJLorton.com and our sponsors by turning off your ad-blocker
